I believe its ver y similar motor to the Brose - if you look at the comments at the bottom of the article i linked to (via google translate so not the easiest to get the true meaning) there seems to be some sort of commenting that they are very similar motors.Looks a bit short, and the geo confirms it - the large (which is the biggest size) only has 450mm of reach. I did ride an early version of the Continental gearbox drive ebike last year and it was pretty awful tbh, but it would be unfair to judge this based on that - the fact this has a derailleur means it must be a completely different power train.
Yep, it definitely is that! "Haibike called, they want their top tube hump back..."450mm reach isn't exactly short...
I think you meant "ugly"
