I’ve had my meta sx two days my first emtb and loving it?But I’ve noticed when I first put the power down weather it be left or right foot I notice a very slight slip probably not even 1 degree in crank movement,I don’t think it’s the pawl engagement at the rear because it kind of happens slightly after I’ve put the power down,it’s almost gives you feeling you’re chain is about to snap,I’ve checked crank arms rear pawl looks pukka and tried replicating it with the motor off checking play in bb etc and can’t find anything,is this just the motor engagement or slight backlash from the cogs inside?is this normal? ?It’s not a problem and I will get used to it?
