Whatever fork you buy needs to beUnless you're buying secondhand the steerer length will be irrelevant as you'll have to cut the new one down to match the length of the existing fork.
Presumably you've looked on the Suntour website using your fork's serial number (on the back of the crown) to get it's measurements and specs?
What are you confused about?
Are you planning on increasing the travel?
What is it about the existing fork that you want to improve?
What type of riding do you do now/plan to do?
What's your budget?
The more info you can post the more relevant and (hopefully) more helpful suggestions people will post.
What's your budget?
for 29er wheel
51mm offset ( normal for a 29er)
Boost ( ie 110mm front hub)
Travel I would suggest no more than 150 since the bike as standard is 130mm.
Tapered steere
Unless you are prepared to spend a lot of money your best bet would probably be something like the RS Pike.....Fox 36 is probably over the top for an XC oriented bike.
As a bove if you are fitting it yourself you will need a steerer cutter and starnut setter.
Hi Jackware,Measure this distance for the current steerer length;
(If you wanted to raise the stem and handlebars slightly you'd want it to be slightly longer)
well done. A good option for the shock would be Fox DPS.Thanks to everyone for the great advice!
Fox 34 e-MTB forks now on!
Whoohoo!
View attachment 85666 View attachment 85667
Nice upgrade! Is there a weight advantage?
Hi there,Thanks for sharing. I like the rear but i am considering a change in front.
Is your fox 140?
Thanks for your input. How much did it cost you?I chose the Fox 34 Rhythm due to their cost, the set I bought were brand new, removed from a new bike that had, had a fork upgrade (although I can't imagine why) If you are interested carrying out this upgrade than there a few things that are worth noting.
Steerer length, the original Suntour had a steerer tube length that I measured at 194mm. Your Fox 34's will need to have a minimum of 182-184mm steerer tube length to have the required 1 spacer under the stem (or a shorty stem). Longer than this will allow you to fit more spacers under the stem to raise the handlebars, alternatively you may need riser bars.
To fit the standard Tektro brakes to the Fox 34's you will need a Shimano SM-MA-F203-PP disc brake mount adapter for 203mm brake rotor.
Whoohoo!
Maybe you can look on facebook on marketplace and find one that was replaced with an upgrade.Heya where did you get the forks? I can't seem to find them on the website.
Maybe you can look on faceboo kon marketplace and find one that was replaced with an upgrade.
The Fox Rhythm & the Fox Performance Elite are OEM forks, that is, these two forks from Fox are only supplied to bicycle manufacturers for fitment to new bikes. In Fox’s range the Rhythm sits at the lower end of the range and is basically a Fox Performance albeit with a slightly lower grade aluminium used in the upper tube & crown. The Fox Performance Elite sits between the Fox Performance and Fox Factory. You can see the various spec differences in the picture above.Heya where did you get the forks? I can't seem to find them on the website.
Hi all, I’ve managed to source a near new set of Fox 34 Rhythm eBike tuned forks.Just looked going to have to be long term desire. I don't see any decent rhythms let alone ones taken off an e-bike. Also looking for 130mm so that seems to be a factor too.
