Stance e+2 2023 - LIV Embolden
skorp_jon
44
25
Slovenia
Frame
Frame: ALUXX SL-Grade aluminium, 125mm travel FlexPoint suspension system, 12x148mm thru-axle, UDH hanger
Fork: SR Suntour XCR 34 LO-R, 140mm travel, tapered steerer, Lockout, 110x15 thru-axle
Shock: SR Suntour Raidon R, custom tuned
Electronics
Motor: SyncDrive Sport 2, 75Nm, powered by Yamaha
Battery: EnergyPak Smart 625Wh EnergyPak Plus range extender compatible
Controls: RideControl Dash
Display: RideControl Dash, full colour lcd screen
Charger: EnergyPak 4A smart charger compact
Components
Handlebar: Giant Connect TR Riser 31.8mm
Grips: Giant Tactal single lock-on
Stem: Giant Contact
Seat Post: Giant 30.9mm, 2-bolt Micro Adjustable, alloy
Saddle: Giant Sport
Pedals: Aluminium Platform
Drivetrain
Shifters: Shimano Deore LinkGlide
Front Derailleur: MRP HD2 co-moulded chain guide
Rear Derailleur: Shimano Deore LinkGlide, 10-speed
Brakes: Tektro HD-M745 Orion, 4-piston, hydraulic disc, (F) 203mm, (R) 203mm
Brake Levers: Tektro HD-M745 Orion
Cassette: Shimano LinkGlide, CS-LG400-10, 11-43T, 10-speed
Chain: Shimano, LinkGlide, CN-LG500
Crankset: FSA Comet E-Bike crank arm setFSA MegaTooth Direct-mount 1X steel 36T
Wheels
Rims: Giant AM 29", Tubeless ready
Hubs: Giant eTracker Boost,
Spokes: Stainless steel
Tyres: [F] Maxxis Minion DHF 29X2.50"foldable, TLR, EXO, 60TPI [R] Maxxis Dissector 29X2.40"WT foldable, TLR, EXO, 60TPI
Other
Lock: Torx 25 Battery Lock with built-in Torque limiter
giant-stance-e-plus-2-2023-black-diamond-002_1800x1800.jpg View attachment 103333 qn5X5xmV0120Mtx54J73pTCVQ.png HKdof6ViBYt_xn_DRrYJ6_rUc.jpg
jeanmarc
444
431
Canada
Is this still under embargo or has it been officially announced? If so, which Country's website? Thanks!
skorp_jon
44
25
Slovenia
I saw it on australian web page. They say in stock for M and XL models.
here it is:
Kiwi Giant
119
134
New Zealand
The 2023 Stance E+2 is listed in NZ at NZ$6999, it comes with the 625Wh battery and comes with a pretty cheap and nasty SR Suntour Raidon R shock, previously this was the lower end but quality RockShox Monarch R. The front fork remains the same from previous years models with a SR Suntour XCR 34 LO-R 140mm which is also pretty low spec'ed. To put this in perspective I paid NZ$5799 in 2021 for my Stance E+2 with a 500Wh battery and the 2022 model with very similar specs to the 2021 is selling on runout at the moment here for NZ$5599 (was retailing before runout for NZ$6399).
Other than the RideControl Dash, full colour lcd screen I don't see any other improvements other than a slightly larger battery (500Wh to 625Wh) for the additional $1200. It remains a 10 speed but the rear cassette changes from an 11-46T to 11-43T which I feel is a retrograde step, the crankset looks pretty similar with a 36T chainring . There is also a change to the motor, now listed as a SyncDrive Sport 2 75Nm, previously was a SyncDrive Sport at 70Nm.
jeanmarc
444
431
Canada
Motor is probably based on the newer PWX3 so smaller and lighter, the other big difference is new more modern geometry. I don't see the 2023 Stance or Embolden on the Giant NZ site?
Kiwi Giant
119
134
New Zealand
I believe it is based on the new PWseries S2 (PW-S2) drive unit with a maximum torque of 75Nm that Yamaha say is 7% higher than the PWseries ST (PW-ST) used in the Stance 2021 & 2022. It weights 2.85kg against the 3.4kg of the PW-ST. As my 2 year warranty comes to an end mid-year I was considering rolling over my Stance but I'm not sure I can justify the additional $1200 for some geometry changes, a new controller, a poorer shock and a less appealing cassette. Hopefully I'd be able to take my front & rear Fox suspension setup over but I can't see the rear shock size anywhere. I already own an 800Wh battery so there's no improvement there...
Evo Cycles & Cycle Science and Pushbikes are all showing the 2023 Stance in stock so I'd assume Giant in Wellington will be able to source as well.
jeanmarc
444
431
Canada
I understand, $1,200 is a lot...
551K
