Stainless chain rings
simonk
SLayer ?
Jan 27, 2020
337
423
Exeter
I’m coming up short trying to find an OEM replacement chainring (SRAM 36t Xsync Eagle 104BCD) for my Trance in the UK. The Praxis eRing Steel Mountain looks to be just the ticket, but I can’t find one of them either. So, a lack of patience and an excess of Pinot Grigio has led me to order a Surly Stainless Chainring.
Should be OK? Or shall I add it, unused, to the large box of items labelled ‘probably shouldn’t have bought that but it may come in handy one day’?
Gary
Old Tartan Bollocks
10,496
10,702
the internet
it should work fine but not having narrow wide tooth design won't retain the chain quite as securely.
simonk
SLayer ?
Jan 27, 2020
337
423
Exeter
Thanks @Gary. There’s an MRP thingy that sits above the chainring, will that offset the lack of fat/thin teeth?
Gary
Old Tartan Bollocks
10,496
10,702
the internet
Yes. I thinkyou'll be fine
A top chain guide combined with the taller teeth on the surly ring should do a pretty good job of retaining the chain.
Ebike chainrings not rotating backwards while riding choppy ground helps with chain retention on the lower chainring as well.
simonk
SLayer ?
Jan 27, 2020
337
423
Exeter
Marvellous. Thank you for your input @Gary .
552K
