2023 SRAM Eagle Key Features:
Robustness & Reliability - The toughest drivetrain ever
Shifting Under Load - The harder you pedal, the better it shifts
Ease of Use - Simplified maintenance, fitting, and operation
@Rob Rides EMTB does the new shifter work with old AXS mechs?
Wonder how it handles the dreaded jumping stick feeding into the pulleys when you're pedalling full tilt though ...
Yes, it’s so clever!
At work just now - will watch it later!if you watch the vid, it shows some pretty robust testing.
You'd need the cassette too. It has it's "rails" and presumably some marking the mech reads to know where it is in terms of 360 degrees of rotation.I wonder how much a GX version will be for just the mech, shifter and chain.
(Assuming any 12sp chain ring will work with it)
That's neat .. but if the stick gets pulled along the bottom chain line and then gets gobbled by the bottom jockey wheel, the chain force will still try to tear the mech off ??
No. Shimano does, but you have to be coasting for it to happen (pretty good though!)I have a question!
Does it shift with the pedals idle like the new shimano di2?
It shifts but it does not change gear.I have a question!
So in order for Specialized Turbo Levo users being able to use this drivetrain, we'd have to use a SRAM crank and chainring, but they don't have a 160mm crank, correct?
I mean just watch some of the videos on it, eg the pinkbike one has him full on jumping on it while it's attachedI got an email about this an hour ago and was reading about it.
My question / fear is that the derailleur hanger is a £10 part that bends / snaps when you catch the derailleur on a rock / log etc. You can carry a spare in your pack and potentially get back up and running at minimum cost.
What happens when you clatter this off something? Does the whole derailleur need replaced?
@Rob Rides EMTB ... Well spotted whilst you were testing it !Eagle AXS Transmission rear derailleur battery life seems shorter than with previous AXS rear derailleurs. Why is there a difference?
Eagle Transmission rear derailleurs have a higher cage damper force than previous Eagle AXS rear derailleurs and therefore require more force and energy to shift the Transmission into inboard gears. Also, the improved shift quality naturally makes riders shift more frequently per ride.
It's actually a myth that the hanger is designed to protect your derailleur. It was initially designed to protect your frame, so if something catches your derailleur, yes it would wreck the derailleur, but the hanger would bend before your frame. Once upon a time the hanger was a part of your frame. When aluminium bikes started appearing, straightening an aluminium section in not a good ideas due to the way aluminium fatigues, so a bolt on failure point was created.I got an email about this an hour ago and was reading about it.
