Sold SRAM GUIDE ULTIMATE BRAKE SET + BLEED KIT/SPARES - £165 inc postage, Uk only.
Esskimojoe
32
Greater Manchester
Bike / Product Year: 2017
Manufacturer: SRAM
Model: SRAM GUIDE ULTIMATE BRAKE SET + BLEED KIT/SPARES
Size ?
Asking Price: £165 inc postage, Uk only.
Location UK
Description SRAM Guide Ultimate brake set, including..
Carbon lever blades
Matchmaker clamps
Galfer E bike brake pads in both calipers
NEW rear hose with brake shroud, torx spanner, stealth a majig/barbs & o rings.
Sram bleed kit with Bleeding edge fitment and bleed block
Extra 3 stealth a majig/barb ends
Post mounts for 203 mm rotors (for 180 mm post mount frame & forks)
Titanium fixing bolts and cup washers.
Great stopping power, modulation.
The rear brake hose has been cut to remove from bike. The brakes were/are in perfect working order when removed from my bike. Front brake is ready to fit. Rear obviously will need new hose fitting and then bleeding. You will need some Dot 5.1 for this. Very easy to bleed.
Any questions please get in touch. 👍🏻
554K
