DaveNewing
Can anyone help? I've just bleed my guide re brakes and I have an issue with the rear brake lever. I put the brake pads in and fitted the rear wheel, then went to pump the rear brake lever so the pads adjust to the disc. After 2 or three pumps the lever is rock solid. It doesn't move the caliper and pads at all, but the lever will not pull in to the bars. Is there anything obvious that could be wrong? The front brake bleed went well and everything works as it should on the front.
