i have a vitus mythique with the advent drivetrain, it has issues with chain slip so im keen to swap it out.
The 1x10 11-48 gearing worked well for me so im keen to stick with it. i have 1x12 GX on my normal bike so am keen to stay with Sram.
the sram 10 speed lists its for 11-46 but will it manage a 48 tooth sprocket?
Also most of the sram 10 speed stuff is listed as 2x10, will it be the same or would it be specced around a different chainline? i have zero knowledge of 2x stuff.
i did buy a shimano long cage 11-51 derailleur for my 11-48 advent setup but found i could not get the B gap small enough (it was about an inch away) so im wary of using incompatible bits and bobs.
