Spring has sprung and my tyre also sprung a leak...
notaninfluencer
72
112
Italy
So have been riding a bit.... (a lot) its 20 degrees... but after this trail today I split a double down maxxis dhr II how do others find them selves getting on with this tyre? pinch flats galore?
Gary
Old Tartan Bollocks
10,496
10,702
the internet
Pinchflatting is caused when the tyre takes a hard enough hit that it bottoms on the rim and the tyre or tube (or both) splits. The simplest way to stop pinchflats from happening is to run higher more supportive pressures.
DD is Maxxis mid casing. a halfway point between Exo and DH casing.
How low a pressure you can run a tyre for any specific casing depends massively on rider weight, how and where you ride and what pressures you're running.
I'd either reconsider your pressures and riding style or switch to DH casings. or if you want the ultimate security from pinchflatting DH casings and inserts.
Personally I don't pinchflat Exo DHRIIs. But I don't run low pressures.
Ps. I've forgotten what 20deg even feels like
Stihldog
Handheld Power Tool
3,494
4,872
Coquitlam, BC
If you ride in an area that requires different tire pressures carry a small pump and gauge. Not only your weight, the weight of an eMTB, terrain, temperatures, speed and style, can become factors that determine tire pressures.
There are more eMTB specific tires that have different compounds and stronger sidewalls available. They’re probably heavier too.
Ps. 20deg is a myth …isn’t it?
Gary
Old Tartan Bollocks
10,496
10,702
the internet
FK dat... run em hard enough for what you're likely to encounter during the entire ride and accept the loss of grip in certain conditions.
The question was about DHRIIs
552K
