Specialized Turbo LEVO Gen 2 (Hot Rod🔥)
Bigjohnmtb
Hong Konh
Here is first EBike. I did some custom/mods, upgrades and install some more durable drivetrain parts and swapped out some of the components. 😎🤘
SWork Turbo LEVO Gen 2 size S4 large.
Dyedbro upper frame protection skin. Use a Wahoo Bolt V2 gps with a 76er top tube enduro mount and a Quadlock bar mount (iPhone 8) to use my BLEvo app.
I swapped out for a more durable drivetrain AXS GX 10-52 with some bling bling uberbike steel coloured pulleys and bling gold Wolftooth crank bolts. Using a Ti Mag Vault pedals.
Loving the Skinwall new T9 Butcher 2.6 (front) and T7 Eliminator 2.6 (rear) on the stock Roval carbon rims.
Big fan of these fat nose Chromag Trailmaster saddles. And wanted to use a cable dropper. Most reliable One Up dropper post.
Ohliins shock with a 605lbs coil spring and Fidlock bottle holder.
Rockshox Ultimate 160mm 29er with Magura 220mm rotor on a set of Danny MacSkill limited edition Raceline Magura MT7s brakes
D MacSkill Magura MT7’s with a 220mm rotor.
Oury grips with a Loic Bruni custom brake lever
Chrysaor
121
124
Switzerland
Nice ride !
I have seen that you wrote steel pulleys, but on Uberbike website I only see aluminium ones. Where have you found these?
I'm asking because I had aluminium pulley and they didn't last long in muddy conditions so genuinely interested to find some good quality steels ones if it exists
Bigjohnmtb
Hong Konh
Nice ride !
Mis wrote. I meant steel bearings. I can see these ones I’ve got are very very durable. And very well made. Give them a go. I don’t think I’ve ever seen steel pulleys. Sry I couldn’t help more
552K
