Sold SPECIALIZED TURBO LEVO COMP CARBON (GEN 2), LARGE, NEW MOTOR, 9 MONTHS WARRANTY, SUPERB - £3,400
Levo Laland
274
236
Surrey UK
SPECIALIZED TURBO LEVO COMP CARBON GEN2 – SIZE LARGE - ROCKET RED/BLACK - £3,400
For sale is my size Large Specialized Turbo Levo Comp Carbon. Purchased new by me in late November 2019 from Berkshire Turbo (I have proof of purchase for the balance of the transferable warranty). The motor and battery are both under warranty until late November 2023 (the battery is only 14 months old). This bike was supplied de-restricted from new and has been returned to almost stock specification except for the fork which was upgraded to the Fox 36 Rhythm 160mm of travel, and the rear chainstays which have been upgraded to the S-Works carbon version (only the seatstays on this bike are aluminium). The bike is in excellent cosmetic condition as it was Invisframed from new (which has been removed prior to sale). The motor is brand new having just been replaced under the 4-year warranty that the 2019 models received. The battery has 100% health and is showing 69 charging cycles. The X-Fusion Seat post has just had a full service at Upgrade Bikes and the forks have had an oil service. The bike has been properly maintained and parts replaced when required. It has recently had the saddle, grips, chain, cassette, chainring, derailer, and pedals replaced. This is a superb all-around electric mountain bike that has been prepared for sale with lots of new parts and has a good balance of the manufacturer’s warranty left. I'm based in Surrey (UK).
The bike is currently fitted with two separate concealed tracking devices, which will not be removed until cleared payment is received.
LARGE FRAME
FACT 9m Carbon main frame, upgraded S-works FACT 11m carbon chain stays, M5 alloy rear seat stay, 29 Trail Geometry, Integrated down tube battery, enclosed internal cable routing, 160/150mm of travel.
MOTOR
Specialized 2.1, custom Rx Trail-tuned motor, 250W nominal (brand new with warranty until late November 2023) This bike was de-restricted from new by Berkshire Turbo Centre.
BATTERY
Turbo M2-500, fully integrated w/ rock guard, 500Wh (14 months old with warranty until late November 2023)
FORK
Upgraded to FOX 36 Rhythm, GRIP damper, 29" Boost™, 160mm of travel.
REAR SHOCK
FOX DPS Performance, 210x52.5, 150mm of travel, 3-Position Adjustment, RX custom tune
SEATPOST
X-Fusion Manic, infinitely adjustable, remote SRL LE lever, 34.9mm, 150mm of travel (just had full a service at Upgrade Bikes and works like new)
BRAKES
SRAM Guide RE, 4-piston calliper, hydraulic disc, 200mm Front & Rear
REAR DERAILLEUR
SRAM NX, long cage, 11-speed (brand new)
SHIFT LEVERS
Upgraded SRAM X1 lever.
CASSETTE
SRAM PG-1130, 11-speed, 11-42t (almost new)
CHAIN
KMC X11, 11-speed (new)
CRANKSET
Praxis, 2D cold-forged alloy, custom offset, 165mm
CHAINRING
34T alloy Works Components (almost new)
WHEELS
Roval Traverse 29, hookless alloy, 30mm inner width, tubeless ready Specialized, sealed cartridge bearings, boost spacing, 28h.
TYRES
Butcher 29x2.6" & Hillbilly 29x2.6" tubeless ready, but currently running tubes.
CHARGER
Custom charger, 42V4A w/ Rosenberger plug
Levo Laland
274
236
Surrey UK
Levo Laland
274
236
Surrey UK
Hello! Do you have receipts for warranty and repairs you've done? Have you weigh the bike?
I have the original purchase receipt for the bike and the replacement battery. I also have the receipts for the recent dropper service and the new motor and a motor power lead as well. Yes, today, the bike weighs only 21.8kg with inner tubes and pedals, so approximately 21kg tubeless without pedals. Previously, I had this bike as low as 20.8kg with pedals. 4D6140F5-3B9D-4012-8C32-5C941DB938EB.jpeg
561K
