Sold Specialized Turbo Levo Comp alloy S3 2022 REDUCED #£2800 #
Dodger1
12
15
Devon. Uk
Hi. I’m selling my Levo Comp Alloy. Size S3,
S3 - Medium165 - 180cm5'5" - 5'11"
It’s not been used too much so has just 213 miles and 7 charge cycles on the battery.
All as standard when purchased from new, will include pedals.
Full specifications below.
Based in south Devon.
REDUCED to £2800.
FrameSpecialized M5 premium alloy, headset adjust, BB height adjust, S-Sizing, internal cable routing, 150mm travel, 148mm spacing
Rear ShockS1: FOX DPS Performance Series, 3-position lever, rebound adjust, 52.5x210mm, S2-S6: FOX FLOAT X Performance, LSR, 2-position lever, 55x210mm
ForkFox Rhythm 36, S1: 150mm travel, S2-S6: 160mm travel
StemAlloy Trail Stem, 35mm bar bore
HandlebarsAlloy, 35mm diameter, 780mm width, 8-degree backsweep, 6-degree upsweep
TapeSpecialized Trail Grips
SaddleBridge Comp, Hollow Cr-mo rails, 155/143mm
Front BrakeSRAM Code R, 4-piston caliper, hydraulic disc, S1-S3: 200mm, S4-S6: 220mm
Rear BrakeSRAM Code R, 4-piston caliper, hydraulic disc, 200mm
Rear DerailleurSRAM GX Eagle, 12-speed
Shift LeversSRAM GX, trigger, 12-speed
CassetteSram XG-1275, 12-speed, 10-52t
ChainSRAM NX Eagle, 12-speed
CranksetPraxis Forged/Custom Offset/ISIS Spindle Interface, 160mm
ChainringsSRAM X-Sync Eagle, 104 BCD, 32T, steel
RimsSpecialized 29, hookless alloy, 30mm inner width, tubeless ready
Front HubAlloy, sealed cartridge bearings, 15x110mm thru-axle, 28h
Rear HubAlloy, sealed cartridge bearings, 12x148mm thru-axle, 32h
SpokesDT Swiss Industry
Front TireButcher, GRID TRAIL casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.6"
Rear TireEliminator, GRID TRAIL casing, GRIPTON® T7 compound, 2Bliss Ready, 27.5x2.6"
Inner TubesStandard, Presta Valve
SeatPostX-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SLR LE lever, 34.9, S1: 100mm, S2: 125mm, S3: 150mm, S4/S5: 175mm, S6: 190mm
Seat BinderAlloy, 38.6mm
MotorSpecialized 2.2 Custom Rx Trail Tuned Motor
UI/RemoteSpecialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, w/Handlebar remote
BatterySpecialized M3-700, Integrated battery, 700Wh
ChargerCustom charger, 42V4A w/ Rosenberger plug, 100-240V
Wiring HarnessCustom Specialized wiring harness
Dodger1
12
15
Devon. Uk
Frame size? Any remainder of 2 year warranty?
Hi. The frame size is S3 (specialized go from S1 to S6 in sizing, there’s plenty of info on the sizes on their website).
The bike was new just under a year ago and I believe the warranty can be transferred on the specialized website.
553K
