I have a 2022 Level R and think it's awesome. I was worried it would not be progressive enough with the coil, but it feels great. It has a low leverage ratio so I don't need to run a heavy lbs spring either (I'm 90kg in gear). I put a 190mm Zeb on the front of mine too but I'm sure it would still be good with the stock 180mm fork.
It is heavy on the scales. Mine with inserts, pedals and 220 rotors is 27kg on the nose. But on the trail it is really a non issue. I've had a Levo and Cube Stereo which are both lighter, but the Level has a much better ride feel and is loads more composed everywhere, including climbing. The better suspension and geo have had a much bigger impact on the performance than the extra weight.
The extra travel on the Rail sounds cool. I put a 170mm fork on both my Stereo and Levo which helped on the downs, but made climbing a bit more of a pain. Hopefully the extra travel on the Rail does the trick for you.
