Solved!
lumpy
🚁 CHOPPER 🚁
Nov 26, 2018
469
441
SF Bay Area
So if your bike isn't getting excited to ride and instead has some "leakage", it's probably coming from outside, like chain lube. Less likely is from inside. I think there is oil in the motor and it could be that, or maybe from something else like a seat post if it's hydraulic.
I think I'd pull off a crank arm and a side cover and see what's going on inside.
khorn
980
1,055
Denmark
There is absolutely no oil inside the engine, only a little grease. If it is oil it must be from an external source.
Karsten
Sep 10, 2018
32
20
Pemberton
Will do
Dax
1,746
2,134
FoD
It's sweating power.
More important things to worry about on your kenevo: is the back axle done up? Is the seat pivot bolt tight?
559K
