Sold SOLD 2019 Specialized Turbo Kenevo Expert, Size Large, Storm Grey, Fully Serviced AND INCLUDES SPARE 504WH BATTERY: £3750
Zerograv80
10
8
Bristol, UK
SPARE BATTERY
Bike / Product Year: 2019
Manufacturer: Specialized
Model: Turbo Kenevo Expert, Size Large, Storm Grey, Fully Serviced AND INCLUDES SPARE 504WH BATTERY
Asking Price: £3750
Location Bristol UK
Description BIKE SOLD BUT SPARE BATTERY STILL AVAILABLE
2019 Specialized Turbo Kenevo Expert E-Bike Size Large, Recently Fully Serviced, AND INCLUDES SPARE 504WH BATTERY Many Brand New and Upgraded Components. £3,750 o.n.o.
Meticulously cleaned and maintained, never pressure washed, but usual paint chips, scratches, rub marks you would expect on a used mountain bike. Fully serviced and in great working order
Brose Motor 2 months old, 100% health, Only 87.5KM on the clock!
504 Wh battery less than 6 months old, only 35 charge cycles, 100% health
Original receipt and service history provided. Comes with charger, Specialized User & Owner’s Manuals/DVD all in original box
Water bottle cage includes SWAT multitool
Also throwing in for free a spare rear mech hanger for you (MY17 ‘Amazinger’ RRP £12)
PLUS I’M INCLUDING A SPARE 504WH BATTERY, practically new, replaced under warranty by Berkshire Cycles, Crowthorne 15/08/20, only 13 charge cycles, 100% health on mission control diagnostics, excellent condition other than the odd small scrape on the bash plate, RRP £800.
SPECIFICATION
FRAME2019 Model Size L (I’m 5’10”) ‘Storm Grey’ Specialized M5 Premium Aluminum, 27.5 Trail Geometry, integrated down tube battery, enclosed internal cable and Command Post IR routing, 148mm spacing, fully sealed cartridge bearings (MAIN PIVOT BOLT REPLACED 14/07/20), 180mm of travel. Bought from Berkshire cycles, Crowthorne and original proof of purchase is provided.
FORKRockShox Lyrik RCT3, 27.5", Solo Air, Boost 15x110mm, 35mm stanchions, 180mm of travel - FULLY SERVICED by RSF MTB Suspension on 02/10/20 £261.00 (combined). Both stanchions in perfect condition, not a mark on them
REAR SHOCKÖhlins TTX Coil, UPGRADED Aftermarket Simon Coventry coil installed day one by Berkshire Cycles135mm 36mmID 625mm (suitable for riders 70kg - 107kg). FULLY SERVICED by RSF MTB Suspension on 02/10/20 @ £261.00 (combined)
FRONT HUBSpecialized, sealed cartridge bearings, 15x110mm thru-axle, 28h
REAR HUBSpecialized, sealed cartridge bearings, 12x148mm thru-axle, 28h, stripped down and FULLY SERVICED by Bad Ass Bikes 07/10/20
SPOKESDT Swiss Industry
RIMSRoval 27.5" alloy, 18mm depth, 38mm internal width, disc-specific
INNER TUBESPresta, 40mm valve
FRONT TYREUPGRADED Schwalbe Addix Magic Mary Evo Ultra Soft Downhill Rigid Tyre 27.5 x 2.60” RRP £100 (pair)
REAR TYREUPGRADED Schwalbe Addix Magic Mary Evo Ultra Soft Downhill Rigid Tyre 27.5 x 2.60” RRP £100 (pair)
CRANKSETPraxis, 2D cold-forged alloy, custom offset, 165mm
CHAINRINGSUPGRADED Renthal 34T, custom steel
SHIFT LEVERSSRAM GXe, one-click lever
REAR DERAILLEURSRAM GX, long cage, 11-speed
CASSETTEBRAND NEW NEVER BEEN RIDDEN Shimano XT 11-speed, 11-42t RRP £90
CHAINBRAND NEW NEVER BEEN RIDDEN Sram 11-speed PCX1 RRP £30
FRONT BRAKESRAM Code R, 4-piston caliper, hydraulic disc, 200mm
REAR BRAKESRAM Code R, 4-piston caliper, hydraulic disc, 200mm
HANDLEBARSUPGRADED Renthal Fatbar 6061 alloy, 6-degree upsweep, 8-degree backsweep, 27mm rise, 770mm width
GRIPSBRAND NEW NEVER BEEN RIDDEN Odi Rogue Single-Ply 3/4 Flange Black Grips
STEMSpecialized Trail, 3D-forged alloy, 4-bolt, 6-degree rise, 45mm
SADDLEBody Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOSTCommand Post WU, 34.9mm, 8mm offset, 125/150mm of travel
SEAT BINDERAlloy, 38.6mm
MOTORSpecialized 1.3, custom Rx Trail-tuned motor, 250W nominal, REPLACED under warranty by Berkshire Cycles, Crowthorne 15/08/20, 100% health on mission control diagnostics
BATTERY (1)Specialized M1-504, integrated Trail Display, ANT+/Bluetooth® module, 504Wh, Replaced under warranty by Berkshire Cycles, Crowthorne 28/04/20, only 35 charge cycles, 100% health on mission control diagnostics
CHARGERCustom charger, 42V4A w/ Rosenberger plug
WIRING HARNESSCustom Specialized wiring harness,
PEDALSRIDDEN ONCE, FWE Thermoplastic Pedals, CNC-machined Cr-Mo axle, LSL sealed bearings, Platform 100 x 105mm, Replaceable pins, Weight per pair 400g
Listed elsewhere so I reserve the right to end this listing early
No swaps
Cash or bank transfer only
Collection from Bristol, UK only
No exceptions
Thanks for looking
557K
