Slight delay bosch cx performance
Stumck13
Arbroath
Hi I’m new to the ebike world. I have a 2023 Mondraker crafty r. Is it normal to have around 10mm delay when pedaling before motor kicks in? And front sprocket spins slightly
6,393
4,865
It's normal when the motor is first switched on......not thereafter as you are riding unless you are in too high a gear. With a emtb spin don't grind!! Get used to using a higher cadence than on a normal bike.
Stumck13
Arbroath
Thanks for your reply yeah it’s when I’m freewheeling then go to pedal again I’ll try using lower gears
544K
