Well like I said I'm 5'8" and Cube recommend a Medium, the height was fine but I was sat off the back of the saddle just a tiny bit but just a couple of tiny changes sorted it for me. Definitely take some Allen keys with you because if you find the same you can make sure the saddle is back as far as it will go and rotate the bars forward a little because small adjustments can sometimes be the answer. As above I actually had to change my saddle and bars to get the bike to fit me but I was going to do that anyway. The height of the Medium is perfect for me with the standard Cube dropper post.Thanks for advice, off to try a medium today but think it’s going to be too small. Unfortunately no larges around
