Yes I got one on mine. If you need the tire space then go for it, but throw some extra frame protection tape around the frame as it will cop it from rocks.
Otherwise V1 does the best job of protection.
You need to remove the frame fork linkage to installed. Not a big work but a work anyway. Then the plastic protector on the fork needs to be removed to fit the smaller part, which i was not very keen to do it.
I didn’t put any tape protection and the paint ended all scuffed.
To be honest the fork get really muddy and lot of stone and dirt collection in between the 2 parts. Aside that I ended up cover in mud on the back so not real protection there either.
a big pebble managed its way in between the tyre and the upper part and brake it.
I thought it will be more sturdy for the price I paid
I ended up removing the hole and install the plastic fork protection once more and clear tape protection all around.
The amount of dirt and mud is pretty much the same... nothing that a good wash can’t manage
They are expensive so I won’t by them again. Very likely go without any rear mud guard
However is someone has a good experience with any other remodel I will be willing to try it
on the positive side the front one works good and I have ride the bicycle with and without and it does make a difference to have it, less mud flying toward your mouth
I have to say the one that mimic finer carbon looks fantastic
Cheers
