I have a Fox Float DPS Shock on the rear of my Levo SL Expert.
I set the shock To a pretty much default setting - approx 25-30% sag, and the rebound / compression set in the middle.
After a few runs, my ShockWiz suggested I needed less rebound - so I turned that down a couple of clicks.
Due to the snow yesterday, my ride was a bit tame.
I reset the ShockWiz this morning, and tried again. This was my results...
On one hand it’s telling me ‘all good’, but the score is only 84%. On the RockShox Deluxe RT3 DebonAir I had on my Rail, I managed to get it to 100% in 2 rides.
Going by the suggestions... removing air from the baseline pressure is simple. I don’t have separate high / low speed compression, so I guess I just turn the single adjustment a couple of clicks?
Air Spring Ramp... do rear shocks have spacers?
On another note... the Fox Performance Elite 34 fork is better than expected - but I feel like I’m missing HSC and LSC on this in comparison to my previous Lyric.
Is there an upgrade to the fork that can add this?
