Shock sizing for 2020 cube 160.
Superkoochy
68
44
Bathgate
I’m looking to swap from my dpx2 factory to a coil shock but I’m not sure what size I will need. Any help would be appreciated.
MrPeaski
260
210
South Wales
From the spec sheet of the 2020 160 AT
Fox Float DPX2 Factory EVOL, Open(Adjustable)/Medium/Firm Mode, 205x60mm, Trunnion Mount, Kashima Coated
Hardware =Top: 54mm Trunnion Mount, Bottom: 22.2x8mm
TM and SL are all the same dimensions (205 x 60 Trunnion mount) and hardware, despite being slightly different shocks
Jona
101
44
Belgium
Did you end up doing it? How does it feel?
Is the frame progressive enough to use a coil shock?
555K
