I recently swapped my bike from a 2020 Levo SL to a 2023 Levo SL, and went to transfer my Rockshox Super Deluxe over as I'd had it custom tuned.
It didn't fit, as the mount was slightly different.
I contacted J-Tech (where I bought it from), and they suggested I should return it and have it re-tuned, as the suspension has a different leverage curve.
I booked it in and sent it away before I went on holiday... for a service, re-tune, and to get the mounts changed. I specifically said the bottom mount didn't need changed as the 'flip chip' end is the same on both bikes.
£25 to book the slot, £169 for the service and re-tune... so £194 later I have the shock back.
Unfortunately, the've added a spacer to the 'flip chip' end, and the flip chip won't fit in it anymore. The top mount has been modified to the correct size.
Can I just attack this plastic insert with a dremmel or something to remove it? I don't want to damage anything. Any tips or suggestions on how to remove it without causing damage?
