Shimano XT Brake Rotor Noise
SuperSpooner
I picked up my a new bike a couple weeks ago and I need some help to diagnose a noise.
It makes a clicking/ticking noise when I pull the front lever and its been doing it since day one when I picked it up from LBS.
I hoped it was brakes bedding in, but ive done 60 miles now and its still doing it.
It only does it when going above 10MPH and only when pulling the front brake.
I swapped the wheel with my other bike and noise goes away. If I ride my other bike with the new wheel the noise is present - so it follows the wheel.
This would suggest its not the calipers, pads, forks, headset etc.
I have replaced the pads and rotors (with the same) and is still present, so to me it has to be the hub, spokes or rim as ive ruled everything else out.
Either that or its normal, but its too loud to be normal and the back brake doesnt make the same noise.
Bike is Cube one55 TM
Newmen Fade hub and Newmen Evolution wheel
Brakes are Shimano BR-M8120
Brake rotors are Shimano RT-MT800 203mm
I attach a recording of the noise. You hear me pedal to get some speed, stop peddling then apply the front brake. The ticking in the second half is the noise.
I will be taking it back to the LBS for their input, but would appreciate any comments or recommendations.
  • Voice 004.mp3
    306.7 KB
SuperSpooner
Yup, that is next on my list of things to try.
I guess all im really after is confirmation that the noise is NOT normal for XT brakes and something else is vibrating and making the noise.
SuperSpooner
So I took it back to the bike shop and they said its normal for XT brakes.
The hole pattern and resin pads just make this noise.
Is this other peoples experience?
There must be many people running 4 pot XT calipers with resin pads and icetech rotors - do they all make this ticking noise?
Hattori-Hanzo
404
526
Same brakes and rotors as you, mine make a clicking noise when rocking the bike stationary/very slow speed, as soon as I'm moving it goes away though 🤷‍♂️
James_C
526
267
Kent, UK
I have XT, icetech and resin pads. I don't think it makes a noticable noise like that.
how are the pads wearing, and are the calipers spaced off the fork mount correctly so that the pad covers the disc correctly?
2WheelsNot4
917
711
Is it a single click or continuous ?
With a single click I think its a bit of play in the rivets that connect the center to the steel disc bit. Hope rotors do this sometimes.
As you first engage it, the rotor rotates a minuscule bit and it makes a click noise. I only use Hope rotors and noticed it for years. Its probably just the same thing and likely nowt to worry about
552K
