Ynk1
Had a big off on the weekend and snapped the brake lever, does anyone know if this can be replaced or will I need a whole new unit ? Photos show the damage
Thanks for that tip , will do that but hopefully not test it ?I don't have your answer, but may help you prevent this happening again. If you do it up enough so that it won't move under normal operation but will if you wrench it. All I do is tighten till I can't move it with a bit of effort. Use thread locker. I've never had a motorcycle or mtb lever break - they just move on impact.
