That's interesting. I had a tiny crash on a small jump a while ago and it bent like a banana. I'm only 75kg too.Have had Miranda 155's on my bike for a couple of years with no issues. I'm not a jumper but also not lightweight. And I see almost no difference to the Shimano cranks.
Gordon
Most say they're more flexible than a gymnast but then again they've won awards for their manufacturing. Odd.
Jordan
Hope are miles behind on pretty much all production of their current range of products so I wouldn't expect anything new from them for a whileAre Hope going to make a Shimano compatible set does anyone know?
I've never understood the difference 5mm or so can make in a crank. Surely just pick a different line. How often can you be striking unless doing trials.
You try riding janky tech and then you'll see. Reason I got rid of the original 160's is because they were like butter too. Everyone I know that's ran anything past 160 is striking pedals to hell. I'm fully aware of line choice and that but an uphill rock garden for example isn't going to be easy, either way.I've never understood the difference 5mm or so can make in a crank. Surely just pick a different line. How often can you be striking unless doing trials.
Ahh thank you for that info, saves me waiting for some Hopes any time soon. I've come from DH biking to ebiking, so I do know when to pedal and when not to. Looking ahead is definitely my strong point.Hope are miles behind on pretty much all production of their current range of products so I wouldn't expect anything new from them for a while
165mm shimano Steps cranks are available. Just calm down look ahead more and learn to plan when to pedal and when not to,when to drop a pedal and when to raise it and learn to time your pedal strokes when climbing. All of this will make you a better rider.
Seen these but I'm in the UK so not ordering anything from Europe any time soon. People are getting absolutely screwed on import tax.160 shimano are available too
STEPS FC-EM600 Crank Arm Set without Chainring
EP8 EXPLORE NEW GROUNDS - Ready to discover unchartered territory? Built on 35 years of pioneering innovation, Shimano E-MTB systems are designed to let you manoeuvre your bike like a regular mountainbike. Blended harmoniously with the...www.bike-discount.de
It does doesn't it! Only 10mm but it's surprising.I went from 170mm cranks to 160mm cranks and it made a very noticeable difference.
Hmmm interesting, I'd never thought of that to be fair. Makes total sense when think about it. My vaults are pretty chunky. Crankbros for example are thinner aren't they. Thanks.I went from thick pedals to thinner pedals, saving maybe 5mm. It made a very noticeable difference, despite only gaining ground clearance worth half of this.
Went back to 170mm cranks from shorter, and it feels a lot different in terms of how big of a circle I have to spin. That alone was a reason for me to want to switch back to shorter.
Gordon
Which Miranda cranks did you put on your Ezesty? length and QFactor number, ive found some Delta 165mm Q16 but i think my FSA are Q8
Jay
Does it ride ok with 160mm onThe Miranda cranks are on my Shimano e8000. On my eZesty, I have a pair of very swish Praxis 160mm Carbon cranks I have yet to break despite smashing them into nearly every rock I can find.
Gordon
Cool I’ve ordered some 160 today, have to tried volume spacers in the shockYep. Fine. I think it needs them as the back end sags a bit under load and I get tons more pedal strikes than on any other bike I own. I am planning on talking to a suspension tuning shop as I don't think I can fit much else in the way of shocks and the back end could be great with a bit of support. I've got the switch in the middle position all the time and I'd like to be able to ride with it more open.
Gordon
