Shimano motor switching self off, no error codes, esommet
Bagpu55
47
11
Stockport
E8000 motor, 250 miles esommet. Over the last couple of rides the motor has randomly shut itself off with no error codes. First time at llandegla I heard two beeps from the display (TBH I was caught by surprise) but nothing was on the display and later in the day it just switched off whilst I was free wheeling. Today the motor switched itself off 3 times again as I was free wheeling? I removed the side panel and the connections are clean and secure (motofoamed), I could probably tighten the battery mount by a mm as a little play? Any other ideas. The speed sensor is aligned.
Battery mount would be my first port of call, along with checking the connections to the display are tight, and to the motor behind the cover. Also check the speed sensor cable isn’t tied too tightly to the swing arm, this can cause it to stretch and break
Casper007
16
New Zealand
I have started to have what sounds to be the same issue. Did you find the cause and a solution?
Bagpu55
47
11
Stockport
Yes I adjusted the battery mount and realigned the speed sensor but the main issue I think was cables pinching above the motor. It was a right mess in there so re-routed and much better although a bit of a pig to do first time. Good practice though and no issues since.
554K
