I have a XTM8000 shifter joined to a BR-M520 brake by an I-spec II clamp. The I-spec II clamp is supposed to offer a greater range of angle adjustment (between brake and shifter). But mine doesn't. In fact it appears to be almost fixed. This is on a newly supplied bike.
Before I start dismantling this, am I right to assume that there actually is a "greater range of adjustment", bearing in mind that this was Shimano's third iteration of an adjustable clamp.
On the "I-spec a" iteration, I had to separate the brake and shifter and use separate clamps in order to get the angle adjustment I was looking for.
