Shimano ep8 Assistance Settings
MTB Hucker
25
13
I had to replace my old e8000 motor (blown torque sensor) on my Merida e160 900e, 2019. I love the bike and have just had it upgraded with the ep8 motor. There's a lot of adjustment with the assistance settings and was wondering what others had change for general trail riding with both climbs and decents.
I've got he first ride with it tomorrow and will be checking out the profile 1 Shimano pre-set.
I'd love any advice and customisations that others have tried that work well. Thanks
RustyIron
1,830
2,850
La Habra, California
I ride almost exclusively in Profile 2 (see below). Profile 1 is for those times when I'm stressed about range.
Most of the time I ride in Eco. If it gets pretty steep and technical, I'll switch to Trail. If the going is almost unrideable without maximum assist, I'll go to Boost. I don't find Boost to be pleasurable for regular riding. These settings seem to allow smooth transitions between assist levels.
MTB Hucker
25
13
This is awesome.
Thanks for sharing all of that. I'll give it a go for the ride tomorrow!
9,380
I use Profile 1 for my trail riding:
I used to have Eco lower and rode everywhere in Trail, using Boost occasionally. But I was burning through the battery. So I increased the settings on Eco and use that instead. I'm getting twice the range and with little noticeable impact. I use Trail on the climbs if I need and Boost where I used to use it before. If I need Boost then I NEED it, so why mess about with anything except the maximum?
Profile 1
Eco​
Trail​
Boost​
Assistance Character
8​
8​
10​
Maximum Torque (Nm)
70​
85​
85​
Assistance Start
5​
5​
5​
Profile 2 is my "get me home" setting. I have never needed it yet.
Profile 2
Eco​
Trail​
Boost​
3​
3​
3​
Maximum Torque (Nm)
49​
85​
85​
Assistance Start
3​
3​
3​
Samwise
83
34
Hampshire, England
Does anyone know what the equivalent the assist setting for are on e8000. Got ep8 motor but not finding the range as good. Has been on default settings so goingntonhave a play about. Found the e8000 sufficient so was going to try adjust eco and trail assist setting so was similar to that and see how that goes or is that a terrible idea?
Will keep the boost most maxed out for when needed
9,380
Set the EP8 max torque to 70Nm which is the e8000 max torque.
You may wish to dial down the assistance character too, but I have no data on what that might be. Assistance character is what brings the bike alive.
Samwise
83
34
Hampshire, England
Good idea, I might even try eco a bit lower. And play around with assist settings.
Thanks for the advice :)
554K
