Shimano ebike motors error and warning codes with solutions
lateh33
Barcelona
Hello everyone,
After encountering the warning codes of Shimano E-bike motors (in my case, Steps EP600 (EP6 2024)), I have created a small table of the main Error and Warning codes, with possible causes and solutions or repairs. It is even recommended to print it out for reference in case of a breakdown in the middle of the mountains.
I am sharing it below and hope it helps.
SHIMANO ERROR CODES: Cause & remedy
Error Code​
Cause​
Remedy​
E010​
An abnormality was detected in the drive unit.​
Check motor connections and wiring.​
E01000 - E01004​
A Sensor abnormality was detected in the drive unit.​
Inspect sensor connections and functionality.​
E01010, E01011​
E01020 - E01022​
E01030​
Sensor failure was detected in the drive unit.​
Replace or repair the sensor in the drive unit.​
E01040 - E01042​
A malfunction was detected in the drive unit motor.​
Check motor connections and inspect for internal motor damage.​
E01050, E01051​
E011​
System error detected.​
Restart the system and check for any updates.​
E012​
Sensor initialization could not be completed normally.​
Restart the system and ensure proper initialization.​
E013​
Abnormality detected in drive unit’s firmware.​
Update or reinstall the drive unit firmware.​
E014​
An abnormal bicycle speed signal was detected from the speed sensor.​
Inspect the speed sensor and its connections.​
E015​
Check all connections in the drive unit.​
E01500​
A communication error was detected between the microcontrollers inside the drive unit.​
Check internal microcontroller connections and replace if necessary.​
E020​
Communication error between the battery and drive unit detected.​
Inspect battery connections and communication cables.​
E02000​
E021​
Battery connected to drive unit conforms with system standards but is not supported.​
Replace the battery with a supported model.​
E022​
Battery connected to drive unit does not conform with system standards.​
Replace the battery with one that conforms to system standards.​
E023​
Electrical abnormality in battery detected.​
Inspect battery and electrical connections.​
E024​
Battery overcurrent protection occurred. (Communication error with the bicycle system)​
Restart the system and check for communication issues.​
E025​
Battery does not recognize the drive unit. (A genuine drive unit is not connected, or the power cord is disconnected.)​
Ensure the genuine drive unit is connected properly.​
E030​
Shifting unit different from system configuration is installed.​
Replace the shifting unit with the correct configuration.​
E031​
The chain tension may not yet be adjusted or the crank may not be installed in the proper position.​
Adjust the chain tension or reinstall the crank properly.​
E033​
Current firmware is not supported by this system.​
Update firmware to a supported version.​
E034 (E013)​
E03400​
E035​
An abnormality was detected in the bicycle settings.​
Check and update bicycle settings.​
E03500​
E043​
Abnormality detected in firmware on this product. Part of the firmware may be corrupted.​
Reinstall the firmware to correct the corruption.​
E044​
Error caused by system configuration.​
Review and correct system configuration.​
E050 (E014)​
E05000​
E201​
E203​
E206​
E209​
E229​
An abnormality was detected from the CAN terminal of the drive unit.​
Inspect the CAN terminal connections.​
E239​
An abnormality was detected from the accessory power terminal of the drive unit.​
Inspect the accessory power terminal connections.​
E254​
E255​
E259​
E295​
E299​
The drive unit entered the Safe Mode because tampering was detected.​
Check for tampering and restart the system.​
E401​
An abnormality was detected in the rear derailleur or motor unit.​
Inspect the rear derailleur and motor unit connections.​
E503​
Electrical abnormality was detected in the freehub.​
Inspect freehub electrical connections.​
E504​
E505​
An abnormality was detected in the sensor in the freehub.​
Inspect the sensor in the freehub and replace if necessary.​
E803​
A setting problem was detected between the freehub and rear derailleur.​
Correct the settings between the freehub and rear derailleur.​
E814​
An abnormality was detected between the units.​
Inspect connections between units.​
E903​
An abnormality due to different settings, etc. between units was detected.​
Update or correct settings between units.​
E905​
An incompatible combination of units was detected.​
Replace incompatible units with compatible ones.​
E906​
E910​
E914​
An abnormality was detected between the drive unit and the battery.​
Inspect connections between the drive unit and battery.​
E915​
The drive unit and battery are incompatible.​
Replace the drive unit or battery with compatible ones.​
E925​
The battery and battery charger are not compatible.​
Replace the battery or charger with compatible ones.​
E934​
A communication error was detected between the cycle computer and the drive unit.​
Inspect communication connections between the cycle computer and drive unit.​
E944​
A communication error was detected between the shifter/switch and the drive unit.​
Inspect communication connections between the shifter/switch and drive unit.​
SHIMANO WARNING CODES: Cause & remedy
Warning Code​
Cause​
Remedy​
W010​
A high-temperature abnormality was detected in the drive unit.​
Allow the drive unit to cool down.​
W011​
No bicycle speed signal was detected from the speed sensor.​
W012​
The crank may be installed in the wrong direction.​
Reinstall the crank in the correct direction.​
W013​
W020​
If the temperature exceeds the guaranteed operating range, the battery output stops.​
Allow the battery to cool down before use.​
W032​
W030​
Two or more assist switches are connected to the system.​
Disconnect the extra assist switches.​
W031​
W10000 (W010)​
W10100 (W011)​
W103​
W10300​
W10600​
W20000 (W020)​
The power was turned OFF due to the temperature exceeding the guaranteed operating range.​
W30200 (W032)​
W205​
W206​
W207​
The traveling data could not be updated correctly.​
Update the traveling data correctly.​
W208​
W209​
W222​
W232​
W233​
Power supply to accessories was stopped due to high temperature abnormality detected in the drive unit.​
Allow the drive unit to cool down before use.​
W240​
W242​
An abnormality was detected from the front/rear light terminal of the drive unit.​
Inspect the front/rear light terminal connections.​
W256​
W292​
W935​
W945​
W954​
A communication error was detected between the rear shifting unit and the drive unit.​
Inspect communication connections between the rear shifting unit and drive unit.​
W960​
A communication error was detected between the CAN connection device and the drive unit.​
Inspect communication connections between the CAN connection device and drive unit.​
W965​
The drive unit and CAN connection device are not compatible.​
Replace the drive unit or CAN connection device with compatible ones.​
W966​
For more information, you can consult the Shimano link https://si.shimano.com/en/error
Regards!
554K
