Hello all. I am new to the forums.
I have a lappiere overvolt HT 2019 with a rear Shimano FH-MT400 hub and a Lappiere 12 mm thru axle.
I tried to remove my rear wheel recently as usual but it was seized solid. I got out the socket set and gave it a lot more pressure and after a few loud click noises it seemed to come loose. What had actually happened is the back nut, cap had instead started to spin with the thru axle. im guessing its rounded itself or the frame out.
The thru axle appears to be seized solid and i am currently spraying it with WD40 to try and loosen it up.
This is the remove side of the thru axle:
This is the back nut side that never used to spin but now does.
Any advice on how to proceed with this would be appreciated. Have i ruined my frame.
Thanks for any and all advice
