Scott Patron headlight
Voluptua
103
65
United Kingdom
The scott website for the 930 model says:
  • Syncros integrated rear fender light
    Front Light Cable pre-installed
I haven't looked at other grades.
Reboot
8
Portugal
Yes, I read that. I can't find that pre-installed front cable anywhere.
Reboot
8
Portugal
Found it. It's tucked inside the headset. It doesn't have a connector though, you have to solder it.
RickBullotta
1,846
1,578
That doesn't seem too smart if that's the "normal" case - could short out easily! Perhaps the connector got pulled off when removing the cable from the headset?
mccoyman
35
13
Belgium
At mine patron it was the same, no connector on it. But the outer sleeve as long as the internal cable. So no issue with short wire, but not user friendly at all
Gorre
7
Brussels
Hi everybody, just got my Patron Tuned and want to install a headlight , witch one can be mounted on the handlebar ?
On the reserved place it can be screwed on I think?
Thank you
Sven
2WheelsNot4
917
711
A front and a rear fender are delivered with the bike, both fenders are tailor made for the Patron for a clean and perfect adjustment. For optimal security, the rear fenders come with integrated LED lights that are directly powered by the motor battery. A cable is already routed, and a plug already mounted on the handlebar for a front light. A range of Syncros accessories are available for the Patron eRIDE such as a kickstand, a rear fender, a rear rack or an action camera mount.
552K
