sani2c on Turbo Levo 700wh battery
CjP
PRIME TIME
1,671
2,394
Everywhere
On my Kenevo with trail setting @50/75 I’ve done 450m elevation and 1600m descending. Never turned the bike off anywhere and had a couple turbo sprints to session a few jumps and came back with 50%
That’s on a 200mm travel bike with draggy tires @15/18 psi and wet/muddy/clay terrain. I weigh 80kg kitted up.
I’d guess on the right tires/pressure, eco setting and turning off the bike everywhere you can you should be able to do it.
Pinned
10
23
Adelaide
I reckon you could do it. I just did 60km and 1800m of climbing on the weekend, specifically to see how far id get out of a 700wh battery. I still came back with 20% because my legs ran out before the battery.
Im 90kg and I had set Eco down to 10% Trail to 30% and Turbo at flat out. Towards the end though i was using more trail and turbs as i was running out of time and legs.
Switching it off would save bugger all IMO, if the motors not being used the only thing on is a couple of led's.
553K
