I just installed a new hope 220 rotor to my 2020 Kenevo using a Shimano 203 adapter which was the only +40 option I had available locally. As you can see from the pic, it looks like the pads should be engaging with, say 1-2mm of the rotor than they are. On the front rotor, the pad contact is even and
about 1-2mm lower than on this one.
First off, is this an issue? What can I do to get the caliper 1-2mm lower? I thought I might run into this by using the 203 adapter. Any help from one of the forum wizards would be greatly appreciated!! Apologies for the bad pic, I hope you can see what I am talking about!
