RickBullotta
Some functional tweaks, some blingy tweaks.
- Not a dropper guy, so swapped out for conventional seatpost & preferred saddle.
- Hated the combo mounts for the AXS shifter and Magura brake levers, so installed separate perches/mounts for each
- Chopped the bar width slightly (I like all my MTBs and motos to be the same)
- Ergon GA2 grips, my go-tos
- Some blue bling (trim rings on MT7 calipers, grips, valve caps - gotta have some style!)
- XTR M-9120 pedals
- Fox fender
In terms of other tweaks:
- Rear lever was mushy right out of the box - made for a bit of a scary first ride. So I did a bleed on the Maguras. Not as bad as everyone claims, nice and firm lever now
- Roughed up the rotors with some 150 grit sandpaper
- Suspension setup changes. Ended up deviating from the Specialized's recommendations with less compression damping overall, 5 psi less in the fork, and a click or two more rebound
- Changed assist on trail mode to 70/100
- XTR M-9120 pedals
- Fox fender
