Etacata
Hi, I have a full eagle set up from another build and would love to put it on my Commencal meta power. Is there any way the front shimano chainring on the e8000 motor can work with eagles 12 speed cassette? Thank you!
You can run any front chainring that fits....what’s on the back can be envy thing you wish as long as the mech, shifter, freewheel are compatibleHi, I have a full eagle set up from another build and would love to put it on my Commencal meta power. Is there any way the front shimano chainring on the e8000 motor can work with eagles 12 speed cassette? Thank you!
Use the current chainring and see how it goes...I doubt you will have an issueI guess my question then would be are there comparable e8000 12speed chainrings available?
I bet it will wear out quicker. I'm gonna try it anyways since the eagle is sitting unused right now. just need to pick up a quick connect link. ilk report back on how it goes.Don’t think you need 12 speed, I can get up every hill with 9, you will never use the bigger gears and I bet the lightweight cassette will wear out for fun.
I use 11 speed di2 on mine...crack on and enjoy fellaI bet it will wear out quicker. I'm gonna try it anyways since the eagle is sitting unused right now. just need to pick up a quick connect link. ilk report back on how it goes.
thanks for the replys?
Until your battery runs out! aaarrrrgggghhhhh!Don’t think you need 12 speed, I can get up every hill with 9, you will never use the bigger gears and I bet the lightweight cassette will wear out for fun.
are those bolt hole comparable with the shimano chairing bolt holes?
rings. thanks for the info gang!!
I'm looking to take a full eagle AXS set up off an existing bike as well and replace the stock 12 speed Shimano XT. Did you try the Shimano Chainring on your e8000 motor with the SRAM Eagle set-up?Hi, I have a full eagle set up from another build and would love to put it on my Commencal meta power. Is there any way the front shimano chainring on the e8000 motor can work with eagles 12 speed cassette? Thank you!
Thanks for the info!yup, worked with no issues.
