Hi All, Any know were you can buy the (Rubber tape chain protector stuff) which come with a Kenevo to stick on the frame to protect and stop the chain slap noise..
Not cheap, but well worth the money. It has far more uses than just chainstay protection. From my experience, it also stays where you put it, and doesn't peel off over time.
My tip.
I haven't seen this mentioned much before but I use Scotch rubber splicing tape (self vulcanising), cheap, indestructible and never comes off. I also use it to make 2 or 3 rubber dampers around the spokes on my brake discs, the end of noisy brakes forever also less vibration on discs extends pad life. Scotch® Rubber Splicing Tape 23 | 3M United States
