Review Roeckl Bi-Fuison gloves
Arminius
565
943
Rhein-Ruhr Delta, Germany
Hi,
Gloves by Roeckl fit my hands pretty well. Having used simply padded ones and a Gel model before I bought this year some new gloves with Bi-Fusion. After a while in use I can share my impressions.
Old Gel and new Bi-Fusion are size 9. The old Gel are a little more loose fit due to wear and tear. On the new Cube TM I had little trouble with deaf hands. With the Bi-Fusion this seems to be solved.
Climate feel is okay and works on touch-screens.
BUT the grip feeling I do not like so much. One thing is the quite thick and sharp cut padding that makes a little indirect feel.. The other thing is the long (deep) gap between the longer pads under the finger line that is present when on the handle bar. It seems not to close the gap between the pads or the handle bar pushes it wider
Well, would I go again for Bi-Fusion or similar? Not as of now but will use them still. And bought a pair Bi-Fusion with short fingers as well. 🫣
Some pics:
552K
