Darnebikers
If you want to upgrade your powerplay from your current wheel from center lock to 6 bolt you're probably getting to know that it's not as simple as swapping wheels, in this case here's what you need.
Rocky uses 3 sensors that the bike cannot work without them and in that case you need this:
basically allows you to bolt this into the 6 bolt hub, also you can't just drill holes into the old sensor as it is not in size.
