RockShox Yari Postmount screws
target2804
55
80
Hey folks,
maybe you can help with this one:
On my new fork I have a Post Mount 6 mount for brake discs with the diameter 160 mm. I drive 203 mm and need an adapter, which I have also already bought. Unlike Post Mount 7, here the adapter is screwed directly to the fork and the brake caliper itself is only connected to the adapter. So there are four drill holes. the supplied screws turn only half into the fork and look 1/2 cm far out when the adapter is screwed into the fork mounting screw holes. In my current fork with PM7 there are two washers each between the screw and caliper. Should I just use them to screw the adapter on the fork or do these always belong between adapter and caliper?
Also I am now missing 2 screws to mount the caliper onto the adapter. Does someone know which ones to buy?
My new PM6 adapter looks like this:
554K
