Rockshox Lyric RC2 Forks Bottom Bolt....C'mon I need the answer
kendo
123
81
All I'm asking is anyone who has a Rockshox Lyric RC2 Fork, mine is 2019 170m on a vitus esommet to please go out turn the bike upside down remove and measure the Bottom Foot Bolt on the air spring side it is black on the left (not the rebound side which has the cap). I know it is an M8 bolt but need to know what the length in mm the threaded part is. I can get one but I'm not paying the £16 for the kit for one bolt. I have a fix in place at the moment. Cheers for the help in advance.??
Mcharza
E*POWAH BOSS
Aug 10, 2018
2,616
5,385
Helsinki, Finland
See this manual https://www.servicearchive.sram.com...manual_2019-2020_lyrik_yari_english_rev_a.pdf
KennyB
824
564
Taunton
If you insist on bodging it, just screw in a bolt, measure the amount it sticks out and chop it off. Just checked mine and it is non ferrous so I suggest you use a non ferrous bolt.
Jackware
Fat-tyred Freakazoid
2,081
2,293
Lancashire
Another option;
Measure in photo online ‐ eleif.net with any decent Google image
KennyB
824
564
Taunton
I refuse to pay £16 for one f'kn bolt....I've spent more the £1500 on upgrades for your info. Point of principle £16 quid for a bolt...no.
It's actually £16 for two special alloy bolts. And I told you it was 14mm on your other thread on this.
Stainless steel bolts in aluminium can cause galvanic corrosion, by the way.
Levo-Lon
177
202
Uk
I was once quoted £32 for a front sprocket nut for a Kawasaki KH250 back in 1985!!
Now that was fookin extortion Nut
Kernow
1,436
1,149
Cornwall uk
Just count the number if threads if you have a photo online of the original ,
Tonytank
100
77
London
Are you scottish? ?
zez3
non-EU(CH)
Thr measurements where taken from an 29" ZEB ultimate but according to sram documentation they are the same on most new fork models
zez3
non-EU(CH)
It was nearly a year ago now, hopefully he’s still not waiting and trying to avoid spending £16! ?
for posterity purposes perhaps, hopefully will help someone else. My search engine results pointed here. It would be a shame not to answer such a simple question.
In my case I needed a 10mm longer thread for some experimentation
554K
