Canmore TLCC 29
Hello, I have had a problem each winter riding in cold weather. The temperature was -18C yesterday, and I set my Levo outside for the tires to reach ambient temp/press. I noticed my RockShox Deluxe Select+ was riding a bit low, so I added air before my ride. After I had the tire pressure dialed in I took off, and then noticed the RockShox Deluxe Select+ was riding low, so I returned and added air to 230 psi. Then took off again. I rode only 1 km and then noiced the RockShox Deluxe Select+ had collapsed. It is now in the shop for a new air can. I had to have the shock sent out to RockShox last winter for a rebuild under warranty. I am hoping my LBS can fix it in their shop this winter.
