Repositioning speed sensor on Range VLT
DaveyPetey
51
16
SLC, Ut
Just built up a Range VLT c2. Was wondering if anyone has moved the speed sensor to a more sure position. Just looks a little sketchy where it hangs now. Maybe even further out on the circumference of the wheel to get a little more speed? PFA
Jansurf77
25
19
Cornwall
I don’t think that would change the speed. It measures number of wheel rotations and how fast each rotation comes around. So no part of the wheel completes a rotation before another part. Hope that makes sense?
RickBullotta
1,846
1,578
Will have no effect on wheel speed/boost as above. A dealer can change the wheel circumference for you or you can use STUnlocker to do it yourself.
DaveyPetey
51
16
SLC, Ut
I don't think that's true. It's measuring the rotation at a fixed radius to calculate the speed, right? Moving it out will make the calculation slower be actual speed.
554K
