Hi guys. I’ve just replaced the standard 60mm stem for a shorter 40mm stem, for my shape and riding position, it is perfect!
However, it’s left a bit of a mess now at the headset. The headset top cover and spacer have a much bigger diameter, look pretty rubbish and are a bit loose. Has anyone else changed they’re stem and encountered this? If so how did you resolve it? I’ve attached a photo to try and show the problem..
