Levo Gen 2 Replacement Rotors on 2020 Levo Expert
KrisScott1990
77
43
Edinburgh
Hi all,
time to replace the SRAM rotors on my Levo expert. Can I use any rotor? Or does it need to be sram centreline? Or could I use a shimano rotor? And to clarify I’ve seen mixed descriptions for 200 and 203mm rotor sizes, can someone confirm which is correct?
also, any recommendations for rotors? Ihave sram brakes and run Uber bike race matrix pads
salko
1,274
865
SLO
Generally you can use any 6-bolt rotor. Stock they came with 200mm SRAM Centerline rotors, for 203mm rotor you will need some washers to lift up caliper a bit.
552K
