Replacement dropper post for Kenevo
Studo
42
27
Bristol
Decided i dont like the lay back on the command post which comes as standard. Recommended repkacements please?
Also whats the biggest drop available that fits?
Dsc
Cambridge
I have an xl troy lee. I have cut 20mm off the seat tube fitted a reducer and a rockshox reverb with new style lever, For me the reverb is the best choice pretty reliable and easy to rebuild.
I am 6' 4" so need an xl but the seat tube was way too long for my liking so with 20mm off the seat tube and a reverb the saddle is right out of the way. WU post Garbage.
UKPHOTO
64
90
United Kingdom
Only recently bought a 2019 Kenevo and the WU is behaving ATM.
However, I am eyeing up/thinking about a Bikeyoke Revive and Wolf Tooth Remote.
Jrwilliams7
116
137
California
This fox seat post and leaver are going on ASAP but requires a conversion kit for the sizing.
Al Boneta
Dark Rider
1,351
2,602
California
I use the BikeYoke Revive XL in 34.9x185mm
It’s kinda expensive, but there is nothing else like it.
The Fox Transfer post requires a sizing shim to fit in the Kenevo.
Keep in mind the Fox post is the same as the Raceface Transfer post and Marzocchi Transfer post and the Raceface seems to go on sale quite a bit more than the Fox.
Slickroots
Oslo, Norway
Just a quick question. Are you able to lower your dropper post any lower in your XL Kenevo?
I’m about to order the Revive dropper post, but I’m not sure if I should get the 185mm or the 160mm for my XL Kenevo. I’m 192cm tall.
552K
