Levo Gen 2 Replaced bearings and still play
beerglass
42
11
Bristol
I've got a 2020 Levo Comp and had all my bearings replaced because I had some play on the pivot
I've done about 3 rides and noticed the play is still there or come back and its this joint below, has some play
What else can it be ? If the bearings have been replaced is there spacers or anything which needs replacing ?
STK
34
15
San Diego
I just replaced the same bearings on my 2019 Kenevo and it seemed like the wear was on the inner race where it contacts the bolt. The new bearings seem to have solved the play but their was some wear starting on the bolt’s black anodized coating. Did you notice this. Also on the Kenevo at least the thicker washer goes on the inside and the thinner one goes on the outside.
553K
