I've got some a significant ding my rear rim (HX1501, alloy with 240 hub). It's deformed enough that the paint is gone and the rim wont hold air. I managed to fix it a few times with some glue/putty to recreate the rim's sidewall profile and get the tyre to seal up OK, but over time the putty is forced out and I go flat. And while it seals OK at first, pushing my thumb into the sidewall of the tyre on the side with the damage lets air escape around the bead at any point around the tyre - not even just at the damage! Though, sealant usually takes of this.
There's also some spokes which have some bends in them from rocks and sticks along the way. And naturally some nipples are a bit rounded from my attempts to true the wheel.
So the question is, having never built a wheel before, can I realistically buy a new rim, and spokes where needed, and lace them to my existing 240 hub, ending up with a good wheel? Or is more likely that I'll create something that wobbles with a whole heap of rounded nipples?
I do have a spoke tension tool, but no truing stand.
Or am I better to replace the whole wheel and cut my losses with the hub?
