Let's discuss on the Red Ped 2 tuning device. It seems to have features that normal (Volspeed, Speedbox) style tuning boxes dont' have.
The functionalities seems to be somewhat same kind that the current Kiox offers with Bosch Ebikeconnect. One could say that it's like the Ebikeconnect done right. Torque and watts are maybe the most interesting data fields:
1: Name of the module
2: Unique address of the module
3: Maximum speed: Reset by a long tap
4: Time travelled
5: Average speed: Reset by long tap
6: Crank turns per minute
7: Current motor support level
8: Current battery power in watts
9: Driver torque at the crank
10: Current speed: Reset all values by a long tap
11: Battery level in percent
12: Driver power in watts
13: RedPed calculated range
14: Driver KCAL
15: Daily distance: Reset by a long tap
16: Current tuning status
17: Total distance: Adjustable by a long tap
18: (Theoretical) Maximum final speed when tuning is active (for setting see instructions)
19: Tuning gets activated when the E Bike is switched on
20: Tuning is activated until the E Bike is switched off
21: Tuning activation via walk button (0 to 4 times)
22: Tuning activation via the light button (0 to 4 times)
23: Tuning activation by switching back and forth to turbo mode (0 to 4 times)
24: Tuning Activation by switching back and forth to the Off mode (0 to 4 times)
25: Counter that counts how often the Walk key was pressed, turns green when the set number is reached, there is a separate counter for 21 to 24.
26: Average crank turns per minute
27: Maximum crank revolutions per minute
28: Battery percent per km, averaged over the last 10km
29: Current battery percentage per km
30: Battery watt-hours per km
31: Average battery watt-hours per km
32: Average battery power in watts
33: Maximum battery power in watts
34: Current torque at the crank in Nm
35: Average torque at the crank in Nm
36: Maximum torque at the crank in Nm
37: Current driver performance in watts
38: Average driver performance in watts
39: Maximum driver power in watts
40: Battery cycles: Reset by a long tap
41: See instructions
42: Wheel circumference in cm or wheel diameter in inches
43,44: See instructions
45: Module name: Maximum 9 characters long
Price is 199 EUR which seem to at same level that everyting else
Anyone using?
4: Time travelled
14: Driver KCAL
Anyone using?
