Levo SL Gen 1 Rear shock adjustment lever.
Ben_H
35
30
Anyth1ng
Hi all, I keep noticing that i am knocking the rear shock adjustment lever whilst riding. I like to ride downhill in the open position, but I think as I ride I must be knocking the lever as its in the medium position most of the time by the time I get to the bottom. I'm relatively knew to getting back into biking and by no means am I sending anything big. I just can't tell if my lever is particularly loose or if I am particularly clumsy. I don't know when I will get chance to try another one on a different bike for comparison. I have done a bit of googling and haven't been able to find out a way of making it tighter/less prone to be knocked.
Has anyone else experienced this issue and if so found a solution?
Thanks,
Ben
knut7
Administrator
667
1,366
Norway
Yeah, that is pretty annoying. I mention it here, at 5:11
I would consider removing the entire lever if I owned one. Perhaps it could be removed, turned 180* and attached again? That way it would point inwards, towards the frame in the open position. Perhaps that can be done with just some slight modifications to the lever?
Ben_H
35
30
Anyth1ng
Well I’m glad I’m not the only one. I’ll take a look and see if I can come up with a solution. Chopping it off seems a bit extreme, but to be fair it’s easy to move so not like you need the big lever down there.
552K
