Levo Gen 2 Rear Shock 210 mm x 52.5 mm or 55mm
beerglass
42
11
Bristol
Hi All
I currently have a Fox float X 2021 which was on a Gen 3 running 210 mm x 55 mm as I took the orange 2.5mm spacer out
I now want to fit back into a Gen 2 which should be 210 mm x 52.5 mm but can't find the orange spacer. Can the Gen 2 run 55 mm ?
Its a Gen 2 2020 alloy in Large
9,359
If you can have a 5mm spacer, you can reduce it in size to convert it to a 2.5mm. I know they are an irregular shape, but just reduce its weight by half. If you don't have an accurate scale, use a balance with what you have cut off on one side and the bit you need on the other. It doesn't have to be 100% accurate.
DuncanDoughnuts
315
171
Cape Town/JHB/Rippon
I run both my Gen 2 levos with 210x55 Float X shocks that I bough from gen 3 owners upgrading to coil.
have not had a issue on either.
Although I did have to add a small Neg volume spacer to get a good feel.
I do however run my bikes in the high setting as I have 27/5 wheels on the back
553K
